file Proxima White dwarf con contenido para SBG
11 Abr 2009 20:33 - 11 Abr 2009 20:39 #145203 por glorfindel III
Pues eso al parecer la proxima white dwarf traera las atributos de las nuevas miniaturas como los hijos de eorl pero para el juego de siempre . la fuente es sacada the las alliance :
www.thelastalliance.com/index.php?pid=view_replies&thread_id=63669&forum_id=59&page=1
esto es lo que dicen:
I got my issue of WD #352 today. They have SBG statlines for all the new models (Sons of Eorl, Stormcaller, Shieldbearer, etc) as well as special rules for the new Hornblower Models for use in the SBG.
A few previews, I think this is legal as I\'m not giving out the full details.
Sons of Eorl get the FV boost, Str Boost, and move like Kingly Horses. Oh yea, and an extra attack. They rock at the tidy sum of a Mahud Raider. Definitely looking forward to adding these guys to my Rohirrim (I bought 5 models when they were on advance).
Hornblowers are similar to Signal Horns for Hobbits as best as I can recall.
Shieldbearer is a minor hero with some cool special rules involving free heroic fights and courage re-rolls.
Druzhag has some special rules that can apply certain furious spells to friendly beasts. He also can share his courage with some of those beasts
Stormcaller is a minor hero and gets access to Nature\'s Wrath as well as a new windy spell. He also gets a special rule that can cause his will to be free.
Amdur - can recover might with certain heroic kills also has some banner like properties.
Usando un traductor dicen algo mas o menos esto:
consiguió mi publicación(cuestión) de WD *352 hoy. Ellos tienen SBG statlines para todos los nuevos modelos (los Hijos de Eorl, Stormcaller, Shieldbearer, etc.) así como reglas especiales para los nuevos Modelos de Hornblower para el empleo en el SBG.
Unas vistas anticipadas, pienso que esto es legal como no doy a conocer los detalles llenos.
Los hijos de Eorl consiguen el empujón de FV, Str el Empujón, y el movimiento como Caballos Kingly. Ah sí, y un ataque suplementario. Ellos se mecen en la suma ordenada de un Asaltante Mahud. Definitivamente esperando con impaciencia la adición de estos tipos a mi Rohirrim (compré 5 modelos cuando ellos estaban sobre el avance).
Hornblowers son similar para Señalar Cuernos para Hobbits como mejor como puedo recordar.
Shieldbearer es un héroe menor con algunas reglas chulas(frescas) especiales que implican peleas libres(gratis) heroicas y nuevos rollos de coraje.
Druzhag tiene algunas reglas especiales que pueden aplicar la cierta ortografía furiosa a bestias amistosas. Él también puede compartir su coraje con algunas de aquellas bestias
Stormcaller es un héroe menor y consigue el acceso a la Ira de la Naturaleza así como una nueva ortografía ventosa. Él también consigue una regla especial que puede hacer que su voluntad sea libre(gratis).
Amdur - puede recuperarse podría con ciertas matanzas heroicas también tiene alguna bandera como propiedades.
Bueno y yo tengo mis dudas en que dice white dwarf numero 352 y la anterior me parece que no fue la 351 sino la ciento algo
Como dice SBG (juego de batallas estrategicas)los atributos supongo que se refieren al juego de siempre pero en la pagina de games worshop no viene nada de que en la proxima white dwarf vengan atributos para el juego de siempre ¿que opinais de esto?
si esto es cierto en el proximo suplemento de elfos no vendran los atributos para el juego de siempre o la mejor si vienen esto no se sabe xD perdonarme si me equivo en algo jeje todavia no me pillao el nuevo suplemento por lo cual no estoy metido en el ajo
y con la traduccion (pesima) se entiende algo mas , pero si alguien que sepa ingles lo resume seria mejor
un saludoB)
11 Abr 2009 21:31 #145206 por Eloykill
Lo de WD 352 es por que en inglaterra lleva publicandose más tiempo.
Hago una traducción rápida.
Sons of Eorl: Los hijos de Eorl. Lo primero que dice no lo entiendo, podría ser lo de +1 ataque y arrollar, pero eso lo tienen todos los jinetes. También pone que se mueven como los \"Caballos Kingly\" (Mearas?)
Shieldbearer: El portador del escudo, creo. Dice que puede hacer combates heroicos sin gastar puntos de poder y repetir la tirada de dados en los chequeos de valor.
Druzag: Puede lanzar hechizos furiosos a bestias amistosas (desbocado?). Lo siguiente es algo sobre el valor de las bestias.
Stormcaller: Puede usar Ira de la Naturaleza y un nuevo hechizo. Voluntad gratis.
Amdur: Puede recuperar might (?) al causar heridas en combates heroicos (similar a khamul). También tiene propiedades banner (?)
Espero poder aclarar algo con esta traducción :P.
12 Abr 2009 00:58 #145211 por erekose
might sera destino y banner estandarte.
supongo no me hagais mucho caso.
12 Abr 2009 01:30 - 12 Abr 2009 01:36 #145212 por glorfindel III
Creo que estas en lo cierto por que pone que Amdur tal vez pueda recuperar con ciertas cosas heroica de la muerte y también tiene algunas propiedades como bandera/estandarte.
pero puede ser varias cosas (lo del destino) asi como recuperar destino matando , cada vez que gastes destino tiras un dado +4 no se gasta o que puedas gastar poder como destino
este costara minimo 150 puntos si tiene P/V/d AL 333
los hijos de eorl tienen movimiento 28 cm ,al igual que los mearas o caballos de reyes , y creo que tendran un ataque extra si carga, es decir que recibiran 2 si cargan o que a pie tengan 2 ataques por lo cual a caballo tendrian un ataque mas (en comparacion a otros jinete) en ambos casos tiran 3 dados ¿¿sera esto ??:dry:
y tambien dice algo de que se parecen a los mahud
no me extrañaria que fuera 15 puntos a pie en caso que tuviera los 2 ataques y por veintitantos ptos a caballo
ah y gracias eloykill por la traduccion
12 Abr 2009 02:35 #145214 por Kratos
Might es Poder, así que acojona mucho el tío ese.
Y sí, banner es estandarte.
Tiempo de carga de la página: 0.124 segundos
